Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Workflow to edit a 3D Package
3 REPLIES 3
kwgochenaur
174 Views, 3 Replies
I am trying to edit the 3D Package for a component I created. I can edit the package, but the changes aren't propagated to the device. If this is just me, could someone walk through the order of operations to alter a 3D package?
Kyle
3 REPLIES 3
kwgochenaur
in reply to: kwgochenaur
Edit/Update: It appears this is because the device is using an older version of the library, i.e., the component is updated in the library, but not in the schematic or PCB. Any thoughts on how to pull the latest iteration of a modified component?
jorge_garcia2
Hi @kwgochenaur,
I hope you're doing well. In the schematic editor, click on the library menu and then select update library. Choose the library and click update. Any components from that library in the design will be updated.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
kwgochenaur
in reply to: jorge_garcia2
Many thanks! For what it's worth, the work you're doing here is worth it's weight in gold to folks like me. I hope it leads Autodesk to a top-notch product and successful industry adoption.
