Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
wire width and clearance
2 REPLIES 2
125 Views, 2 Replies
Hello?
After update.
Errors continue to occur in wire width and clearance.
I don't know what the problem is.
help.
M1 MAC Book Pro & Intel MAC Book Pro
Sonoma
2 REPLIES 2
jorge_garcia2
in reply to: 7912661
Hi @7912661,
I hope you're doing well. The best place to check what the clearance errors are caused by is to look into the DRC and Netclasses. Whatever is causing the violation will show up there.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Thank you.
Thank you for your kind advice.
But I solved it another way. Following Autodesk's advice, I exported to Eagle and then re-imported, so the problem did not occur.
