This seems really dangerous. I have a footprint (From snapeda). This is how it looks in my library:
Here it is in the library.
Here it is placed:
Clearly the hole and pad size has changed. I mean, you can't just do this. Do I have to now manually check every single footprint I use in case the tool just decides to change it?
I assume this is going to relate to some DRC setting somehow but this is not cool.
---Edit---
I'm trying to have an open mind using this tool, but it is not easy. The way annular rings are calculated and then changed is pure madness. One might think the answer would be to specify a small enough annular ring in the DRC settings but no, you also have to account for the vague percent column which is not explained in the DRC menu. But if you search long enough you can find in a ten year old eagle thread https://eagle.suggest.eng.narkive.com/2nfikC83/prevent-restring-on-pads-that-are-not-defined-with-an...
It's encouraging that people have been asking for 10+ years for this to be done better.
