Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Where is the Pin-To-Pad Connect equivalent in F360 Electronics
3 REPLIES 3
dieter.menne
899 Views, 3 Replies
To be absolutely sure I am working without EAGLE vestiges, I am working on a computer with recent Fusion 360 only and have tried to create a library.
Symbols, Footprints and Packages can be created. Package can be associated to footprint. Works fine and smoother than in EAGLE.
I could not find the place where to associated Symbols with Footprints. Where is the equivalent of the EAGLE dialog below?
2020-02-01 19_03_12-Library Basics Part 3_ Creating Devices _ EAGLE _ Blog.png
3 REPLIES 3
You have to disconnect the pin/pad relationships to be able to re-assign them.
Once everything is connected (as shown in your image) - you have no options left.
Carlos Acosta
Factory400 - YouTube|Instagram
There were no previous connections, because as I wrote I uninstalled EAGLE cleanly and rebuilt the small devices totally from scratch to learn the Fusion workflow. The image is from the web, just to show which box I needed.
So how do I find the equivalent of this box in a Fusion-Only workflow.
dieter.menne
in reply to: dieter.menne
One can easily miss it, because by default it is VERY narrow and hides behind Inspector/Selection
