Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
what happened to the link/update warning from an eagle push update or ECAD????
1 REPLY 1
Bruce
131 Views, 1 Reply
Hi all,
maybe it is just me, im perplexed by the dissapearance of the "chain link" logo/ yellow triangle warning, that occurs when i make an change in eagle. (or in 360 ecad, new file or imported from eagle) There used to be a warning/ notification that a newer pcb version has been pushed from Eagle, and you guessed it, asked if you would you like to update you mechanical model.
Of course says i, since i was the one who changed it. This happens All the TIME, as a designer of both the mechanics and hardware electronics. No workflow is rigid.
For a very long time, i continued to used Eagle seperately, because frankly, its great, the first iteration of ECAD on fusion was total $&*£, for reasons already known.
But alas, this week, i cant i figure out why the "chain link" facility has disappeared, between my dragged and dropped/inserted pcbs, and the mechanical assemblies. Sure, inserted mechanical components still have there little link/chain logo, but where did the electronics links on go?!
If i had hair, it would be pulled out by now.
From what i can figure out, the link remains missing even if i:
1- Have timeline on in F360 mech for a pcb insert, (im not a timeline fan), but i switched it on just to allow inserts to happen.
2- use old imported Eagle Scm & pcb, where F360 ECAD accepts imported  SC, PCB, and lib.
3- create a completely new  simple scm/pcb/3d-pcb within F360.
4 - cross my fingers with a rabbits foot in other hand.
i too - and - fro all the time, due to space restraints, cost, simplicitity between scm, pcb and Mech. its a pain to have delete and insert, and move 3d pcb every time now. Work around or solution asap!
1 REPLY 1
Bruce
in reply to: Bruce
UPDATE:
In urgency, i just found a workaround/hack/bodge, while using Eagle 2 F360 pushes on an old f360 3dpcb file.
- this may help highlight where the issue is for Dev folks.
this works with Eagle, doing the pushes to F360.
1 - find a old, not used anymore 3d pcb file from a couple of months ago, that you dont need anymore, lying in F360 - (a copy and rename works too, but it has to be from sometime ago) - insert this into the F360 mechanical assembly etc that your working on. - you can tell if the Chain - link symbol appears, that its going to be a sucess at this point.
2- optional - rename inserted old file, so finding it will be easier.
3-go to Sync to f360 tab inEagle, remove any existing link that doesn't work anyway, steer to this already existing 3dpcb file of type above, and link to it.
4- the changes were effective after a Eagle 2 F360 push - even when the source pcb eagle file was completely different to the old 3d pcb file.
5- when any changes then made to scm or PCB in Eagle are then pushed; F360 would pick up on this with a refresh offered, and the yellow triangle warning comes up that things have changed as exspected.
