Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
What happened to file history?
2 REPLIES 2
robert1356
80 Views, 2 Replies
I was using Fusion360 Electronics today and in the project panel on the left the history has disappeared.  The version number is there, but when I click on the version number, the panel that appears just lists the "last update" in more detail (with the time and which part of fusion360, pcb, etc).   Where is the list of all the old versions??  What if I need to go back to an older version?
Labels (3)
2 REPLIES 2
jorge_garcia2
in reply to: robert1356
Hello @robert1356,
See the attached picture. Is this not what you are seeing? If it's not could you post a picture of what you are seeing?
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
robert1356
in reply to: jorge_garcia2
No, that is not what I was seeing.  I was seeing only the top part of that history pane.  However, as it was late, I shut down and came back to it the next day and it was working fine the next day.  I think there may have been some network issues because I was also having trouble duplicating and deleting files.
This is no longer an issue - must have been poor connectivity.  I would recommend UI components that require time and data to load should probably have some indication that loading is happen or at least a place holder image that indicates there is more to come, not just not displaying it until the data arrives
