Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Weird behavior when moving hole
2 REPLIES 2
infinite.machinery
132 Views, 2 Replies
I have a hole in my board that I want to increase its Y position by 2mm. In the inspector I increase the Y position by 2. Rather than simply moving the hole, it moves the hole and also leaves the original hole in place, resulting in this bizarre shaped hole. Why is this happening? I just want to move the position of the hole.Hole Problem 3D.PNGHole Problem.PNG
2 REPLIES 2
Hello @infinite.machinery,
In which editor are you making the move? Is there any chance you have move that one one hole overlapping the exact same location? That's what it kind of looks like.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
I was just using the board editor. I'm sort of stumbling my way into the new way of doing things in Fusion 360 and using a blank schematic to create a simple panel from a board design. I've scratched that project and I'm now using QCad for the panel project, which is working better for a 2D project.
