Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
WEB GL error when uploading stp file to library
3 REPLIES 3
32loyal
154 Views, 3 Replies
Whenever i try to upload a 3d model to a device i receive a error saying There was a problem running web gl on this machine and it will only render wireframe.Unfortunately nothing is rendered in the window only the 3 axis move triangle i have tried all the workarounds posted in the thread https://forums.autodesk.com/t5/eagle-forum/trouble-in-lunching-package-generator-in-eagle-8-7-1/m-p/... none of them worked.What else should i try?thanks
3 REPLIES 3
32loyal
in reply to: 32loyal
Found a work around just goto library.io in your browser and login with your autodesk account,then just upload the 3d model through there website this issue seems to be a eagle/fusion issue shocker a issue with fusion i know, my browser works with the same exact webpage eagle says it cant support.
polaris360
Most users can get the issue fixed using the solutions in https://forums.autodesk.com/t5/eagle-forum/trouble-in-lunching-package-generator-in-eagle-8-7-1/m-p/...
Can you share your graphics card and OS information?
32loyal
in reply to: polaris360
In My first post i said i already tried those methods with no change
