Warning! - Deleting attribute in inspector panel breaks F/B annotation
Hi All,
Fusion Electronics makes it very easy to break the F/B annotation and quite difficult to fix once it broken.
Here is a particularly easy way to break the F/B annotation.
1) Open any Electronics Design that has board and schematic that are consistent
2) Select any component from the schematic (double click it to show the inspector pane)
3) In the inspector pane, right click on an attribute line and select delete (interestingly, delete it is the only option)
4) Save your Project and close. (you will receive no warnings or indications that things are broken)
Open the project and you will find that Board and schematic are no longer consistent.
Upon further inspection, you will find the attribute was deleted from the part in the PCB design, but not in the schematic.
I use the windows version - not sure if this is a trouble in the other versions
Kevin
