Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
User Library-SMD CAPACITOR could not be uploaded because access to the "PCB projects"project was denied. Please contact the project moderator for assistance.
8 REPLIES 8
Message 1 of 9
mark4GG4A
255 Views, 8 Replies
I can not find the source of this error message that keeps coming up. I have looked everywhere and can not find a library called SMD-CAPACITOR anywhere or anylibrary . Does anyone know how and where to find this error so I can get rid of it...its really annoying it keeps coming up literally every minute or so
8 REPLIES 8
Message 2 of 9
yqliu
in reply to: mark4GG4A
This error usually happens when you are saving a document which is owned by others but the access permission was removed. Based on your description, this is not your case.
Can you share your Applog file to me?
https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/sfdcarticles/sfdcarticles/How-t...
Message 3 of 9
mark4GG4A
in reply to: yqliu
These are the log files in the Aoplications log
Message 4 of 9
mark4GG4A
There are 18 log files...I cant see all of them there for some reason
Oh can only load 3 files...also I am not on the usual computer I use. I will do this again when I get back to work on monday. These log files may not contain the correct information
Message 5 of 9
yqliu
You are right. The log files here contain no information related to the error.
Message 6 of 9
mark4GG4A
in reply to: yqliu
This is from the work computer. There are only 2 of the application log files here
Message 7 of 9
yqliu
The problem is because uploading a STEP file failed. You can search "ced78437-0065-4d34-a772-2157a3b01ae9.STEP" in your Fusion 360 installation folder (/Users/Work/Library/Application Support/Autodesk/Autodesk Fusion 360/) and check which library/part is using this STEP file.
Message 8 of 9
mark4GG4A
in reply to: yqliu
I found the files and deleted them but the problem seems to still be persisting
Message 9 of 9
mark4GG4A
in reply to: yqliu
Do I just delete the files or is there a special way to unistall them
