Unable to use Miter tool
friedl.basson
friedl.basson
Hi -
I am unable to use the Miter command.  I select Miter, stipulate the radius and then hit OK.  After this, I proceed the the corner of the board, but when I click the cursor simply change to the move cursor.
I have also watched the video on how to do this, which is exactly the procedure I follow.  I have done the often in Eagle as I always use rounded corners on my PCB's.
Would appreciate some guidance, I might be overlooking something trivial, first time using Fusion Electronics.
Many thanks in advance.
Regards, Friedl.
RichardHammerl
Hi @friedl.basson
reading the description of the workflow, I have the feeling that "hit OK" is the problem.
If you click on the OK button the command will be terminated. Please hit the enter key after you type in the radius....
Does this solve the problem?
Best regards
Richard Hammerl
friedl.basson
Hi @RichardHammerl
GREAT thanks! Worked like a charm.  Much appreciated.
Kind Regards,
Friedl
friedl.basson
@RichardHammerl
Sorry not sure why the font in the response was "strike through"  🙂
Friedl
