Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Unable to delete polygon cutout
2 REPLIES 2
j.lodder
229 Views, 2 Replies
In my board there are polygon cutouts on layer 2.
I'm unable to do anything with them, except copy and use the change tool to move layers.
The properties dialog is all greyed out except the lock tickbox.
Can't move them. Can't select them.
I want to delete them, but this does not work.
How to remove them?
All polygons on layer 2 appear to be immutable, yet they are not locked. When changed to another layer they can be modified and deleted.
Fusion 360  2.0.11186
2 REPLIES 2
j.lodder
in reply to: j.lodder
Resolved it... you can lock layers!
This has not much to do with the views of layers, but it does make the layer immutable, but does not mark the objects as locked. It can be very useful.
Unfortunately there is no way to tell a layer is locked, except from this small greyscale icon in the layer view settings.
And you can only lock layers from the menu, not unlock....
Plus "unlock all" does not unlock layers.
In my opinion this feature needs some more polish, since I've just wasted a lot of time. Maybe this:?
jorge_garcia2
Hi @j.lodder ,
THank your for the suggestion, I will report your feedback. Kudos for making the mockup.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
