Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Unable to change the default dimensions/units/size/grid in Fusion 360 Electronics
1 REPLY 1
sbatra.work
80 Views, 1 Reply
I am trying to change the default dimension on the PCB LAYOUT and the FOOTPRINT in Library of Fusion 360 Electronics.
Please see the screenshot attached below.
Can someone please help me with the steps? I am unable to locate the default script file for this. I also looked in the preferences/settings within the Fusion360 Application and couldn't find anything.
1 REPLY 1
jorge_garcia2
in reply to: sbatra.work
Hi @sbatra.work,
I hope you're doing well. Fusion 360 doesn't use the eagle.scr like EAGLE did. You can still run it, but it won't persist.
Defaults are now setup in the Fusion 360 preferences
Let me know if you continue to run into problems.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
