Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
.ulp mirror-board-remirror-element-swap-layer not working
4 REPLIES 4
itTNYMJ
215 Views, 4 Replies
I'm working in Automotive lighting and I designed a PCB layout for the left side (rear lamp), I tried to use this ulp to mirror the board and swap layers (for the right side) but it is not working : errorlevel-99. Is there any other solution ?
4 REPLIES 4
jorge_garcia2
in reply to: itTNYMJ
Hi @itTNYMJ,
I hope you're doing well. I just tried it and it worked in Fusion 360, it looks like it might be related to the design itself. When you run the ULP, make sure to save the file it wants to create to the desktop or something like that.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
itTNYMJ
Hi, Thanks for replay, unfortunately still doesn't work; what do you mean by "can be related to design itself" . I only receive this message and nothing happen; if I press OK the message appears again. Also I get this error.Fusion360_.PNG
Cristian
itTNYMJ
I have checked with other design and seems that it is working; I will recheck my design, do you have an idea what to looking for ? Because I don't have any errors in DRC.
Thanks for support
jorge_garcia2
Hi @itTNYMJ,
That would be hard to guess at.  Make sure you're DRC is set up for two layer boards 1 and 16 since the error seems related to those two layers.
Best Regards,
Jorge Garcia
