- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi
I need use "mount-smd-tht" ULP.
But after click "ok" I can't find the file.
Anyone know where are I can look?
Hi
Hi @Kristey ,
I did not look into the ULP closer, but saw that it is not possible to decide on the folder where the file(s) should go to. I added a quick and dirty file dialog option to the attached ULP. Now you could select a folder.
Please try it, but I do absolutely not consider this as a perfect solution..... but it could help you now.
Thank you for your time !
Thank you man, you saved me the day!
