UI feature missing for drawing lines on silk layers
I can't figure out how to draw lines on a silk layer in Fusion Electronics, other than by creating a library part. This was/is straightforward in EAGLE.
Related question: Is it possible to create traces without connecting them to pads, vias or existing traces? This was possible by holding down a key in EAGLE, but I seem to not be figuring out how to do this in FE.
Workaround:
The LINE command actually works, it's just a missing button/menu.
jorge_garcia
Hi @Anonymous,
Document > Draw you'll find the LINE command there. For FE we have to conform to Fusion360 UI conventions so stuff got moved around. It's a pain for me too, but it's just a learning process to get through for now.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
