Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Two of the three boards I have made so far have had strange gouges
1 REPLY 1
markY6RWE
115 Views, 1 Reply
Here is a board I did tonight, The green lines in the toolpath even show the bit contacting the board on a rapid move to the next location using Contour. Not sure why these random things are happening.
Line 4765 X0.0434 Y-1.286 Is the bottom right green toolpath. There is no Z command before the move.
Is there a way to display line numbers of the gcode while simulating, That would help to insert or correct the gcode before routing. I have to load it on mach3 and run it to find the line to correct or insert.
1 REPLY 1
panpan_fan
in reply to: markY6RWE
Hi @markY6RWE
I hope you are doing well!
For your question, do you mind sending your file to us so that we can find out the issue quickly.
I will send my email to you as a private message.
Thanks!
Panpan Fan
