Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Trouble with Gouging attached file
1 REPLY 1
markY6RWE
144 Views, 1 Reply
I am still having a problem with the Z access staying down between some moves using contour to rout a board.
There three areas on this board I have circled in dark blue, the green path is the gouge where the Z axes is not
raised before moving to the next area.
I have tried many settings in the contour selections , nothing stops them.
Labels (1)
1 REPLY 1
shengrui.xiao
in reply to: markY6RWE
Hi @markY6RWE ,  you can set the "Maximum Stay-Down Distance" value to 0, so that the Z axis will always retract before moving to the next area, hope this helps you solve this problem.
