Trouble Creating My Own Component
bhuntZJAHM
bhuntZJAHM
I need to create a schematic symbol for some custom switch with LEDs devices. I was able to create my own Component, but I imported some other elements to make the drawing easier. I have the image that I need, but it's saved as a Symbol in my Component. When I try to use it on a new Schematic, I can browse to my Library and my Component, but I don't see the Symbol I created.
Any suggestions on what I'm missing here?
Bernie
jorge_garcia
Hi @bhuntZJAHM,
I hope you're doing well. In order for the component to be useable in the schematic it should have a footprint associated to it. If you intend for the component to not have a footprint then in the component create an attribute called _EXTERNAL_
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
bhuntZJAHM
Jorge,
You have the second half of the problem. I found I had not added the schematic to the component. Once I did, then I got the foot print error that you recommended. So I'm up and running , Thank you.
