Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
transferring project to eagle
1 REPLY 1
kris.chlapek
176 Views, 1 Reply
Hi All
Can someone please advice on how to transfer my entire work that I`ve done in f360 to Eagle?
I`m fed-up with how slow thigs are and willing to go back where I should never leave.
1 REPLY 1
tedEUQZT
in reply to: kris.chlapek
The straightforward way to transfer out of F360 would be to open the design, then switch to the schematic and use File->Export to create an Eagle 9.x SCH file, then switch to the layout editor in F360 and do the same thing, File->Export and create an Eagle 9.x BRD file. You should then be able to open these in Eagle.
A more convoluted way, if you think you'll ever want/need to try going to back to Fusion is to use the Fusion360 link between Eagle and Fusion (right edge of Eagle window, if the files have never been in Eagle you may need to create blank placeholders):
