Transferring mechanical construction lines to 2D PCB
I was watching the "Defining PCB Outline from Existing Geometry" tutorial and applying it to a design I've been working on. I was able to create a board outline with bolt holes based on this tutorial, but I was also hoping to be able to transfer other existing geometry onto the PCB so I could reference it during electronic component placement. In my particular case, I have button holes in the enclosure that I'd like to use for reference when placing the button components. Initially when I was creating the board outline sketch, I converted the projected button hole geometry into construction lines so that it wouldn't be considered when generating the board outline. I was hoping that this might get transferred to a "documentation" or "construction line" layer in the 2D PCB so I could use it for reference.
Is there functionality to do something like that? If not, are there plans to add it?
