Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Track segment selection intermittent
7 REPLIES 7
Message 1 of 8
scott.nortman
231 Views, 7 Replies
When editing my PCB, there is inconsistent behavior of the track segment selection; please see the video, perhaps I am doing something incorrectly?
https://drive.google.com/open?id=1I54WsIVEKVN2fuKwqY9SMP903LhY_m8j
7 REPLIES 7
Message 2 of 8
Another video of the issue:
https://drive.google.com/open?id=1ILm9XXlR5eLXaugl24ZA1ArPk2dWPEJz
Please help...
Message 3 of 8
rbeyerCLBSZ
in reply to: scott.nortman
If you are just trying to rip up a track, select the "rip up" tool instead of the selection tool and try that. Same goes for moving tracks, use the "move" tool instead of the selection tool.
Message 4 of 8
scott.nortman
in reply to: rbeyerCLBSZ
Thanks for the suggestion, but that is not the point; I need to delete a segment of track and I can't even do that because I can't select it.
Message 5 of 8
rbeyerCLBSZ
Selecting isn't necessary for using the delete tool (I know, the instinct is to select the track and hit the "delete" key). However if you select the delete tool, you can just click on any track without selecting it first.
And yes, I agree that this is a problem, just trying to figure out if the problem is with the select tool, or selection in general. If you can use the delete/move/etc tools by themselves (without selecting first), this may narrow down the issue for the Autodesk developers.
Message 6 of 8
scott.nortman
Nothing is working...
When I click on the rip up connected copper tool and then the track, nothing happens.
When I click on the 'garbage can' delete first, then I click on the track, nothing happens.
When I attempt the same actions a few times, occasionally a track is selected...
This is super frustrating
Message 7 of 8
Figured out the issue...
When you have a wide track, I has assumed that you can click anywhere on the width of the track to select it; however, that is not the case; you need to click very close to the 'imaginary centerline' of the track.  Once you do that all works OK.
Message 8 of 8
kb9ydn
This is one of the things that makes object selection in Fusion Electronics (and Eagle) rather obnoxious.  Hopefully someday they make FE work more like the rest of Fusion in this respect.
C|
