Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Trace snaps to via
2 REPLIES 2
eduardo.barcellos76YM4
291 Views, 2 Replies
Trace snaps to via
I'm trying to draw a trace from a via, but I can't because if I try to end the 1st line of the trace too close to the via the trace snaps to the via. Look:
This is the minimum distance I can get:
If I get any closer, this happens:
It snaps to the via. How do I change this snap distance? I tried changing DRC/Clearance/Same Signals all to 0, but no change. This trace has to bend close to the via as I'm modifying a differential pair, and I need to modify it by hand (not using the differential pair feature).
2 REPLIES 2
It's hard to judge the image without scale but I'm guessing you could adjust your grid/snap settings which might allow a closer approach to the via before the software infers that you want to connect to it. Another option would be to draw the trace at a wide berth from the via and drag it in to complete the route.
Steve Ritter
Manufacturing Engineer
AutoCAD/Draftsight
Inventor/Solidworks
Fusion 360
I tried changing the grid but it doesn't help. What are the snap settings you mentioned? Is it at DRC/Clearance/Same Signals?
But yes, drawing a longer trace and then dragging it closer works. Thanks for that information. Also, when I just created the via (drawn a trace then pressed space) it then allows me to get as close as I want when drawing the next trace on the other layer. But after finishing drawing it, if I try to draw another trace from that via, it then snaps, not letting me to get any close to the via's center.
