Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
TPlace components drifting off as I rotate
1 REPLY 1
andrewbarry3000
118 Views, 1 Reply
Hi all look at both pics below. I rotate 180 degrees and the + and- drifts off a bit. Whats causing this? The circle diamteter does not move at all-Andrew
1 REPLY 1
Hi @andrewbarry3000,
The reason for this is that in the original library the negative and plus sign don't perfectly line up with the origin of the part. Whenever the part was made the creator of it probably eyeballed their location.
It won't create any problems for manufacturing if that is what worries you. You can always copy the part to your own library and change it there.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
