Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Though hole pad drill size can't be set above 1mm
1 REPLY 1
lewisQFHF4
867 Views, 1 Reply
I'm trying to increase the size of my through hole on a PCB design above 1mm in diameter so as to be able to accommodate a larger wire thickness (19 AWG / 0.9116mm). I'd like to set it to 1.5mm. Why does the designer GUI show now difference when the value of the 'Drill' is set to anything higher than 1mm?
Is this a problem of the software, me or something else?
Lewis
Labels (4)
1 REPLY 1
lewisQFHF4
in reply to: lewisQFHF4
I've solved it - I hd to add the unit 'mm' after entering a larger value than those already available in the drop down (even though they do not end in 'mm'.)
