Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Thermal connection for polygons and vias and visibility in 3D of internal layers
2 REPLIES 2
oleksandr_velihorskyi
257 Views, 2 Replies
Dear community,
how can I configure the thermal connection of vias to the polygon in Fusion 360? In my case, PTH pads are connected with thermal connections, but vias - with direct connection.  I have not found how I can set it in the parameters, except the checkbox "Thermals" in Inspector, but it was affected only on PTH pads. Is it possible to distinguish some vias (for example, small stitching vias should be with direct connection, whereas some special - with thermal? Please see the attached image.
Another question about visibility of internal layers (4 layer board). When I have pushed the board to 3D, I can see only layers 1 and 16. Internal signal layers are not represented. Is it as it should be, or the bug?
2 REPLIES 2
Hello @oleksandr_velihorskyi,
I hope you're doing well. The 3D PCB can only render layers 1 and 16 for performance reasons. So this is how it should be.
By default all vias will be solidly connected to polygons. You can adjust a setting in the DRC that will have all vias getting thermal connections. There is no easy way to have some get thermal connections and others not.
I would recommend that anything that should have thermal connection might be best served by being made into a component.
Let me know if you're doing well.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Kudos are much appreciated if the information I have shared is helpful to you and/or others.
Thank you for the explanations.
