Announcements
there is problem in fusion 360 Libbary
mdtusherkhan231
Community Visitor
mdtusherkhan231
Community Visitor
Community Visitor
hello there,
i am using a student version of Fusion 360, in this version I am not able to find a lot of ICs like ATmega, LT series and other. although there some IC able able in libbary, is not eongh for learning PCB desine. so i requested the fusion team, please update those libbary.
thank you
jorge_garcia
Hi @mdtusherkhan231 ,
I hope you're doing well. Go into the Library Manager, you'll see there are many libraries that are not enabled by default. You'll find that we ship with a few Atmega libs. You can also enable the Sparkfun and Adafruit libraries which will give you access to most of the arduino style ICs.
Let me know if you continue to run into problems.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
