Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
The grid setting in Fusion 360 Electronics has to be setup every time! have any solution?
8 REPLIES 8
Message 1 of 9
micro9997
781 Views, 8 Replies
Is there any way to set my setting as default?
8 REPLIES 8
Message 2 of 9
panpan_fan
in reply to: micro9997
Hi @micro9997
I hope you are doing!
For your question, do mean that you want to save your grid settings for specific file?
And for this function, we have do some improvement for it. And it will be in the next release.
I will keep you updated when we release it.
Best Regards,
Panpan Fan
Message 3 of 9
I am on the edge of my seat.....
Carlos Acosta
Factory400 - YouTube|Instagram
Message 4 of 9
jroddisRT8HL
It's killing me having to change from imperial to metric every time.. especially when every data sheet on the planet is in metric.
Message 5 of 9
panpan_fan
in reply to: jroddisRT8HL
Hi @jroddisRT8HL @micro9997  @engineeringNCMXB
Sorry for all the inconvenience.
For all your problems, I think they should be fixed in the next release.
Thanks again for participating in Fusion 360 Electronics Forum.
Panpan Fan
Message 6 of 9
panpan_fan
Hi @micro9997 @jroddisRT8HL @engineeringNCMXB
I hope you are doing well!
Today we release Fusion 360 V2.0.9636. Now the settings of grid can be saved in your schematic and PCB files.
You can got to Preferences, then go to Reset Grid Tab. Choose Check/Uncheck those seleections.
If you want to save your grid settings in you schematic/PCB, you can uncheck those selections.
Then your grid settings will be saved. You can reopen your files to double check.
There is a reminder that your change for grid settings will not activate the Save button directly (For some reasons, our developers make the decision for this scenario).
It means that you need to do other changes to activate Save button, but I think it will not affect your workflow.
Please have a try, thanks!
Panpan Fan
Message 7 of 9
Perfect!
I love to see progress. Especially seeing progress that is driven by the end users.
Carlos Acosta
Message 8 of 9
jroddisRT8HL
A seemingly small but great quality of life improvement, thank you!
Message 9 of 9
michel.linckels
Hi all,
The solution may come a little late, but it's a great help for me, and maybe for you too.
I have created shortcuts to change the grid settings. These can then be assigned to F keys, for example. This allows you to switch between different grid settings at the touch of a button.
This is the command instruction for my inch Grid:
GRID ON DOTS INCH 0.05 1 ALT 0.025
(Grid->ON, Style->DOTS, Size->0.05inch, Multiple->1, Alt->0.025inch)
and this for my mm Grid:
GRID ON LINES MM 1 5 ALT 0.1
(Grid->ON, Style->LINES, Size->1mm, Multiple->5, Alt->0.1mm)
I hope it's helps
Mike
