Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Text on copper
2 REPLIES 2
708 Views, 2 Replies
Text on copper
i'm trying to place a copper text on my pcb.
Does anybody know which layer i have to place the text on?
Regards
Jakob
2 REPLIES 2
RichardHammerl
Hi @Anonymous
thank you for your participation in our forum.
As I understand you would like to have some text written in the copper layers, right? So you need to place the text in layer 1, Top or layer 16 Bottom. Depends on where the text should appear.
Or do you plan to have some text visible as copper, for example on a ground plane? If yes, you would write the text in layer tStop or bStop. Now the solder stop mask is open (not covered with laquer) and copper is exposed.
Hope this helps.
Richard Hammerl
in reply to: RichardHammerl
Hi @RichardHammerl
I wanted the text to be visible as copper, as you mentioned in the second part.
I followed your instructions and got what i planned to get.
Thank you for your fast reply and the solution @RichardHammerl.
Best regards
Jakob
