Hello @silvio3105 ,
I'm not sure if this is the right solution to your problem:
Hello @silvio3105 ,
then you have just do that in the corresponding layer.
Are you really sure to to that in silkscreen (Layer 21/22, tPlace/bPlace)?
Or do you want it in layer 29/30 (tStop/bStop)? So there is no solder stop where the text is.
Hi all,
have you found a solution for negative text on SilkScreen layer? E.g. like in Arduino board?
It can be done with a ULP, not that easy.
For a tutorial: https://atadiat.com/en/e-negative-silkscreen-eagle-ulp/
Note that you use the ULP for fusion.
Just tested it myself and it works.
Thanks. Is it a set of lines, as I can see? Is there another option to have a polygon on the silkscreen layer? I mean, the lines can't be scaled after creation.
