Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Text Label Orientation
1 REPLY 1
dfitterman
222 Views, 1 Reply
I am using the  Document>Draw>Text to put a label on a PCB. I want to rotate some of the text 180° so it is right-side up when the top edge of the physical board is closest to the viewer. Using rotate for 90° or 270° properly changes the text orientation. However, when I set the rotation to 180° the text is not upside down on the screen as I want it to be, but rather right-side up.
What's the trick to making this work?
Labels (4)
1 REPLY 1
yqliu
in reply to: dfitterman
@dfitterman wrote:
I am using the  Document>Draw>Text to put a label on a PCB. I want to rotate some of the text 180° so it is right-side up ...
I guess you mean to say bottom-side up. Please try the "Spin" option.
Technology Administrators
