Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Team library
5 REPLIES 5
VertigoMFG
478 Views, 5 Replies
Team library
Hey awesome humans!
Setting up a new project in Fusion Electronics, what is the best workflow to make sure other people in my team can open schematics etc without getting library errors.
Are the components included in a design saved to that design or do I need to create a separate library and upload to the project just to achieve this?
5 REPLIES 5
edwin.robledo
in reply to: VertigoMFG
Hi VertigoMFG,
Thank you for participating in the Fusion 360 electronics forum. That is a GREAT question. There are few ways to approach this.  I would recommend creating a project folder in which share with all the members of your team.  Place all the libraries in this folder that you are using for your schematics.
With Fusion.360, once you place the component on the schematic, it no longer requires the library. All the information for the component is contained in the Schematic. Sharing your schematic will not generate errors if other team members open it.
Just as a side note, it is possible to export components from the schematic into a library. Proves useful if you need repurpose components and you don't have the library 😀.
I hope this helps.
Best Regards,
Ed
Edwin Robledo
Tech Marketing Manager
VertigoMFG
in reply to: edwin.robledo
Thanks, @edwin.robledo  that makes scene.
Would be awesome if you could do a video on this at some point could be really useful.
edwin.robledo
Hi  VertigoMFG ,
Thanks for the tip, I will put something together.
With Warm Regards,
Ed
Edwin Robledo
I see this was resolved last year. Where do I find the video for this?
jorge_garcia2
Hi @MLeskowUAKV8 ,
I hope you're doing well. Check out this series of videos that highlight the library workflow.
https://www.youtube.com/watch?v=xNIEXCimRSg&list=PLmA_xUT-8UlI0k9YsKK23onh_0VV2_DP5&index=7
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
