Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Team Libraries dont update in open schematics when changes are saved
3 REPLIES 3
tedEUQZT
109 Views, 3 Replies
Because I have 4 engineers working on related PCB designs at the same time, we use a number of shared Fusion Team libraries, and have a designated Library person creating parts and footprints.  When she saves a new part in the Team Library on her computer, I can open this library and see the part, but the Place Components in a schematic on my system never changes unless I quit Fusion and restart.
(a) The version number visible in Library Manager on my system is stale, and there is no way to manually get the schematic sub process to acquire the update, the library file itself cannot be re-added to the project since it's already In Use, and neither "Update Design From Library" nor update all affect this,
(b) Closing the Electronics Project and re-opening without quitting has no effect, Library Manager shows the same version, note that I also made sure there were no other electronics projects open,
(c) Opening the Library for editing from the Fusion Cloud browser directly displays the correct version number and parts/properties, so the data is available to my system just not getting propagated to the Eagle container, likely because Fusion is creating a local cache file of the library at the time it starts up. Possibly the container process has that temporary file open which would prevent Fusion from writing an update to that temporary file.
@jorge.garcia - any chance the developers could add a button or function into the main Fusion application to forcibly close and restart the Eagle container so that updates can be propagated without having to quit the top level App? Even better would be allowing us to kick the embedded Eagle binary to see changes to the library files.
3 REPLIES 3
jesper8W75R
in reply to: tedEUQZT
Have you tried giving it a little time?
I guess you have, but for me, that is sometimes necessary.
After saving a 3D model, for instance, I cannot save the library for a while, because the upload of that model is in progress.
And, when I finally save the library, I have to wait a bit before I can use the "Update design from Library" e.t.c.
Sometimes 30 seconds to a minute.
It usually works for me that way, but it is a bit shaky. I also have problems sometimes with getting the right versions into play.
jorge_garcia2
Hi @tedEUQZT ,
It's nice to hear from you. Coincidentally, I heard a developer mention something like this and that he's working on it. I'll reply if I get confirmation that this is indeed what he's addressing.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
jorge_garcia2
Hi @tedEUQZT ,
So I got word from the developer and this is being worked on. In the meantime you should be able to force the update by using the import from team function in the library manager. This is the failsafe that was put in for any type of update or libraries not appearing issue. See the image
Jorge Garcia
