Suggested behaviour improvement for DRC
Just a quick suggestion: When selecting a "Wire Stub" error in the DRC errors list, it would be a big time saver if Fusion 360 could automatically select the stub, so we can just do a quick visual check and press the delete key. What often happens is that the stub is sitting underneath a wire you actually want to keep on the same layer, so selecting the stub is tricky and takes some poking around. Tweaks like this would make the app less frustrating to use.
Josh
Link copied
