Announcements
Stackup for 1 layer MCPCB
FritsVuyk
FritsVuyk
How can i  put this in the Layer Stack Manager?
Replies (7)
BoyuanLi
Hi there,
The way to speficy single layer board:
Go to Document -> Layer Stack Manager -> By default, you will see the drop down list contains "2 layer Stack", click to open the drop down -> In last row, click "Open From Setup String ..." -> In the setup box, input "1" (top) or "16" (bottom).
Hope this helps.
Best,
Boyuan
FritsVuyk
I can't select Aluminium as a base. It is not the Material layer list. Many people use MCPCB's in the Led industry
jorge_garcia
Hi @FritsVuyk,
I hope this message finds you well. I'll put this in as a feature request. With that said you don't have to worry, you can still get your design done. The stackup information doesn't make it into the gerbers so the board house can use whatever stackup they prefer.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
FritsVuyk
Thanks Jorge, to put this in as a feature request.
For now i can't realy use ODB++, because of the incorrect stackup information.
Coming from Eagle, I am used to make gerber files and a separate fabrication drawing with the board stackup.
(additional info: my board manufacturer uses TCB-8 from polytronics)
FritsVuyk
Just wondering if there is any progress in adding 1 layer metal-core's in the stackup
The feature request by Jorge is more than a year ago...
jorge_garcia
Hi @FritsVuyk,
I hope you're doing well. Nothing to report on this yet. I thought I had created the ticket but I couldn't find it. So I have made a new ticket and added details about the need for metal core substrates.
Best Regards,
Jorge Garcia
RomanR9999
Got it working now!!
