Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
SPICE simulation. Can not setup voltage source
2 REPLIES 2
arsvivendi1234
787 Views, 2 Replies
When running a SPICE simulation in Fusion 360 (Operting point) all Voltage is 0 Volt.
When trying to setup analog voltage source the following error appears:
You must select a part with SPICEPREFIX attribute value of V or I to use this feature. Use MAKESPICE to make changes.
I do not know where to find MAKESPICE or how it works.
Can you help me with this issue?
Thanks in advance.
Arnd
2 REPLIES 2
Hello @arsvivendi1234,
I hope you're doing well. Have you place a voltage source from the ngspice-simulation library? The error would seem to imply that you don't have a source in the design to stimulate the circuit. I would start there, the error is a little misleading since you don't usually access the MAKESPICE command directly.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Hello Jorge,
the voltage source from the ngspice-simulation library works.
Thank you for the advice!
Best Regards,
