Hi @Kristey ,
I hope you're doing well. Did you run ERC? (Make sure you actually click ERC and not ERRORS).
This happens when you click NO, on the dialog asking you if you want to join +5V and N$24. Let me know if there's anything else I can do for you.
Best Regards,
Sorry, I meant ERC. I don't have any mistake.
I understand that this happens when I say no in the call notice but there should at least be a warning in the end.
And we could set a default for this situation, because I'm not seeing any situation in which we use a "source" and we don't want the net to have that same name.
Hi @Kristey ,
You may not have an error, but there should be a warning. Can you confirm?
I agree that there should be a default behavior, however it is caught by ERC I just checked trying it out here. So you should be notified of the issue. Make sure to run ERC and look at the error and warnings, there will be one that says supply X overwritten by Y or something to that effect where X and Y are signal names.
Best Regards,
