Announcements
Soldermask opening on SMD pad in 3D view
In the 3D view,
we have to see the copper where the soldermask is opened on the pad.
See the copper by transparency is good, but also the soldermask have to respect the gerber, cause sometimes we've got geometry on soldermask.
or for example here on copper jumper :
Any correction ?
Thank you
Regards
Replies (9)
jorge_garcia
Hi @Anonymous ,
Are you talking about the silkscreen or the stopmask? Everything looks good as far as I can tell in the image above.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Hi @jorge_garcia
Thanks for your reply,
Yes, we're talking about stopmask.
If we look on the cam preview it's correct, the copper appear in gold color here.
But not on the 3D view,
It could be great to have the same stopmask (or called soldermask) as the real board.
Thank you
Regards
everettac
I believe this is showing the same issue as my post.
Yes, it's same as your post.
Sorry for the dupplication. I searched for "Soldermask" but I didn't seen your post.
So, Maybe they will correct it on a futur update
jorge_garcia
Hi guys,
This is a known issue. The developers are working on it. Thanks for bringing it up.
Best Regards,
Jorge Garcia
It hasn't been yet fixed. I see the same issue in 3D view today, year later.
Any plans to fix it this year?
- Sergey
jorge_garcia
Hi @Anonymous ,
Thanks for the post. There are plans to fix it soon, but I can't say for sure if it will be this year. What I can say is that it is being worked on and not on the todo list. If priorities change then that might be delayed but that's what I know so far.
Best Regards,
Jorge Garcia
The only workaround so far is to use EAGLE and push the design to Fusion 360 (button on the right side).
The results then look like this:
everettac
As mentioned in this post in the original thread on this topic, this feature has been implemented for component footprints in the May 2021 release if you click on the "View 3d PCB with Options" option within the "Switch" dropdown menu. You can then click on the "Stop Layer Geometry" checkbox, which will enable the feature for a standard 3d PCB.
