Announcements
Soldermask issues in 3D PCB
erik.hole
erik.hole
I have had issues with getting soldermask to work correctly as advertised in the few latest updates. When trying to change soldermask color, the soldermask dissapairs
As well as the issue with the missing soldermask pullback is still persistant
Hope this can be fixed, as I would like to utelize the new drc feature advertised in the July update.
Best regards,
Erik Hole
panpan_fan
Hi @erik.hole
I hope you are doing well!
Thanks a lot for your feedback!
I do some testing for change soldermask colors and most colors work well for me.
I will suggest you to change the Alpha Channel when the soldermask is obvious to see.
Please have a try to see if it works well for you, thanks!
Panpan Fan
erik.hole
I tested that, and some colors work, but colors as white is not working.
