Silckscreen layer transfer problem in CCI 3D
hardwareTD5FS
hardwareTD5FS
I have a problem with one of my projects. When I display the silkscreen canvas, top or bottom, a white square appears instead of the silkscreen. Here's the 2D map with only layers 20 Dimension, 21 tPlace and 25 tNames:
Here's what I get when I do the 3D transfer and bring up the top screen printing canvas:
I've been doing a lot of research and trying to set parameters since yesterday, but I'm still stuck on a white square on this project, whereas on other projects the screen printing appears correctly, as in this one for example:
In addition, I think that the silkscreen mask layers are not transferring, and there's an icon that seems to indicate that the silkscreen image is missing:
Can anyone help me with this problem?
Thanks in advance!
Ju
yqliu
@hardwareTD5FS , please check if there is any text or other objects outside of the board outline. If so, try to change the position, push to 3D PCB again and see if it helps.
Richard
hardwareTD5FS
I found the solution. It was just because the board outlines wasn't really closed(a few millimeters after the commas of difference between two point of the dimensions drawings). The board i use was a trasfer from an old eagle board trasfered to Fusion. I'm supprised to not having showing an error during the errors check of the board or durinng the transfer between the 2D and 3D PCB but it's that!
Many thanks!
hardwareTD5FS
Error of post, if a moderator can suppress this message.
