Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Show Milling Contour in Fusion 360
1 REPLY 1
msingler25H6P
162 Views, 1 Reply
I have here a PCB with a milling contour. But when I upload the board to Fusion360 you can't see the contour.
Does anyone know how to export the milling contour?
Sincerely
Maximilian
1 REPLY 1
Hi @msingler25H6P ,
I hope you're doing well. The milling layer is meant for defining cutouts, from the first image is looks like maybe you are using it to define a centerline or maybe a score. In those contexts you don't see anything removed from the board. So right now it's behaving as designed.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
