Should be simple Mapping electronic library
Ok, I am trying to figure out what I am doing wrong. I am importing a schematic, a footprint, and possibly even a package and component so that I can slightly edit the footprint of a component. Everything seems to work fine. I have each of those created under the proper tab of the content manager. However, when I go to map the pins with the footprint so that I can actually use the component in my design it doesn't work. While under the components tab, I can click new and find the footprint that I have edited... great. Now I need to connect it to the schematic that I have also edited (removed a pin and removed a pad in footprint). However, I only see the pad numbers. There are no pins showing up to connect to. I am having this problem often. I have some how managed to make it work a couple of times, but I can't for the life of me figure out what it is that makes it work. Please help!
Thanks!
