Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Shortcuts not working properly (COPY/F4)
1 REPLY 1
vfprivate
104 Views, 1 Reply
In electronic desing (EAGLE, chematic) is COPY function assigned to F4 key. Pretty simply (attached image). Reality? Does not work. Pressing F4 causes the cursor to jump to the command line (go through list of last commands). Why? How can be this solved?
What I need: press F4, call COPY function and click and copy a part in schematic
What it does: press F4 -> cursor jumps to the list of last commands
Version: Fusion 360, 2.0.10148
@AutodeskCould be Fusion 360 at least as good as EAGLE by Cadsoft? There are many other problems that the old EAGLE does not have.
Labels (3)
1 REPLY 1
jorge_garcia2
in reply to: vfprivate
Hi @vfprivate ,
I hope you're doing well. The shortcut system in Fusion 360 is completely different to what is available in EAGLE. We are aware of this and are working to address it.
With that said, In Fusion you can use Ctrl+C to copy in the normal manner so you don't need to go the F4 route. In that sense it's a more typical shortcut.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
