shift selection when selecting a sketch
net-marker
net-marker
When I make a sketch and then want to select it for editing, the marker is shifted upwards. I hope someone can help me solve this problem.
Replies (10)
jeff_strater
share your design here.  I doubt that it is the selection that is off - it looks from the images like the lines themselves are separated by a bit.  Can you constrain those lines to be colinear?
Jeff Strater
Engineering Director
net-marker
Hi, Thanks for the replay,
As you can see on the picture ( and I have double-checked this) is the line going from left to right through the square. So there is absolutely no extra line or lines that can be separated.  Also, I see the issue happening in different places in the same sketch file. It is really strange 🙂 . Attached some more pictures of the issue
jeff_strater
thanks, but I can't tell what is going on only from pictures.  If you can share your design, someone can take a look at the design and determine more about what is going on.
Jeff Strater
net-marker
Ok herby the file. on the picture, you can see where to find the sketch. or there a link https://myhub.autodesk360.com/ue29ccde8/shares/public/SH919a0QTf3c32634dcf1510212719d0c196
jeff_strater
thank you for sharing the file, @net-marker .  I was able to see the issue you pointed out, and have created bug FUS-60871 to track it.  It is clear that the profile and the curve mismatch in that area.  I'm not sure which one is "correct":
Jeff Strater
net-marker
Hi Thanks,
I just created a new design to try it out. and it seems I have the same issue thair as well https://a360.co/2P2Ej2T
net-marker
Hi Jeff, Anny idea when there will be a solution. I currently can't continue my work as long this is not fixed. It is simply impossible to design something good like this.
jeff_strater
@net-marker - we don't currently have a complete understanding of this issue.  However, I strongly believe that it is just a graphics issue.  I suspect that the profile is rendered correctly, but the curve is not.  But, the underlying geometric data is correct and reliable.  If you extrude from these designs, your results should be correct and accurate.
Jeff Strater
net-marker
Hello Jeff,
I'm sorry to say but as you can see in the file is that the underlying geometric data is NOT correct and reliable. When I extrude and cut out some parts small parts in the thickness of the deviation are NOT cut out. This proofs that what I see is also what I get. And what I see is incorrect. I completely reinstalled the software and created a new design. I however still keep having the issue.  Please take a look in the provided links to try it out yourself.
Thanks Net marker
jeff_strater
@net-marker - I have discussed this with our graphics team, and they have verified the basic description I provided above.  Any graphical representation of a geometric object will always be an approximation.  In this case, the approximation used for the curve and for the profile do not agree, so this apparent gap is shown on the screen.  The underlying data, however, is still accurate, and can be relied upon for operations such as machining, etc.  There is no loss of accuracy here, you can ignore these small graphical differences.
Jeff Strater
