Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Set 2DPCB size unit in inspector to mm as default
1 REPLY 1
majedationE43S5
70 Views, 1 Reply
When I create a 2DPCB from a schematic, the size unit in the inspector is shown randomly each time, without me changing the unit in the preferences. Sometimes they are both the same, either "mm" or "mil", and other times they are different, as shown in the screenshot attached.
I've went through the preferences, but didn't see an option for unit for "Width" and "Height" separately.
How can I set both "Width" and "Height" to mm as default?
Thanks.
1 REPLY 1
Hallo @majedationE43S5 ,
you can set units to "mm" as default in "Prefereces". See Screenshot:
Edit:
Now I see the "failure" Width in mil ans Height in mm:
Seems to be a "bug"
Eagle 9.6.2 / Fusion 360
Working with Eagle since Version 3.x
