Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Service Utility Not Responding
1 REPLY 1
RCBakerBorn
92 Views, 1 Reply
I tried to run a Repair Fusion 360 Electronics from the Service Utility Menu and it is not responding.
What gives? I can't open Fusion 360 Electronics, I can't repair Fusion 360 Electronics.
I paid for Fusion 360 electronics but can't use it.
This cloud based version sounds like a great idea, until you can't access it as readily as a downloadable software version.
The free version of Eagle was better than this as well.
I am frustrated.
Please help to restore my confidence in this expenditure or it will no longer be an expense.
I have attached a log file to assist in resolving this issue.
Thank you.
1 REPLY 1
jorge_garcia2
in reply to: RCBakerBorn
Hi @RCBakerBorn,
I hope you're doing well. My colleague is suggesting that you follow the procedure in this article
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-do-a-clean-...
In the meantime, I'll make a ticket with your logs. Is there anything special or unique about you computer setup?
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
