Announcements
Server error when trying to import package from "old" EAGLE into Fusion 360 Elec
dieter.menne
dieter.menne
I have imported an lbr file on my computer from EAGLE into Fusion Electronics. I did not find a way to import a managed library, though.
Importing Footprint and Symbols worked, when I tried to open the package after a lengthy explanation/OK I got the Internal server errora.png
Replies (7)
edwin.robledo
Hi dieter.menne,
We appreciate your participation on the Fusion 360 forum, it great to hear from you.  Please make sure that you are login on to Fusion 360 using the same account that was used to generate the library. This discrepancy might be causing this issue. I have reported this to our developing and they are currently looking into it.
Please let me know if the following steps provide you access to your available remote libraries.
Appreciate if you can keep us informed of your progress.
With Warm Regards,
Ed
Edwin Robledo
Tech Marketing Manager
dieter.menne
Thanks, everthing is there when I access the library that way. Looks I was lost in GUI space, but nevertheless the error message is probably not what Captain Picard appreciates.
edwin.robledo
Hi dieter.menne,
Your response is greatly appreciated. Glad to learn you will be able to continue working with our recommendation.
"Live Long and Prosper"
With Warm Regards,
Ed
Edwin Robledo
dieter.menne
Sorry, I have to partially take back my acceptance......
I wanted to EDIT an existing package, so I used open to open it on my computer. This works partially, symbol and footprint are ok, package crashes with the error message above.
I had expected to find something like "open manage package for editing".
dieter.menne
I understood "It needs to be copied to WIP (what's that)" that the app will do the copying. Or do I have to do it manually? How? In EAGLE?
Error message as in OP after that. Login was with the same account.
dieter.menne
Maybe related. In EAGLE, I can log in and create new managed libraries. However, when I try any of the "View this on the web" links, I get, both with Firefox and Chrome. Cookies are enabled
dieter.menne
Looks like the error occurs when the EAGLE component has not been completed. I finished everything in EAGLE, Created new library, and things are working.
