Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Schematic File Startup Error Pointing To Local User App Location
1 REPLY 1
onthelevelinspectionllc
109 Views, 1 Reply
Had an error on startup complaining about a schematic file error.  Looked at the file and could see no problem.  Technical support resolved the problem upon looking at the file.  It turns out the footprint was missing from the 3D package causing the error, likely a problem from a supplier download part model.   The most simple solution is find another model for the same component, or at least the same footprint and reload it into the library and use it in place of the model causing the errors.   Errors and info attached.
Labels (1)
1 REPLY 1
Solution indicated by replacing model with another
