Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Schematic color scheme
6 REPLIES 6
ruben.crispino
256 Views, 6 Replies
Is there a way to change schematic color scheme from the Eagle scheme to Fusion360 electronics and vice versa?
Labels (1)
6 REPLIES 6
Hello @ruben.crispino ,
yes, there is:
  • Profile -> Prefereces -> Electronics:
Eagle 9.6.2 / Fusion 360
Working with Eagle since Version 3.x
That setting enables the possibility to change between Light and Dark but not from the eagle color scheme to the default Fusion360. Is there something else I am missing?
Hi @ruben.crispino,
I hope you're doing well. By default, we are now shipping with the old EAGLE colors if I remember correctly. With that said if that's not what you are seeing you can grab the old defaultcolors.scr from your EAGLE installation and run it in Fusion 360. That will get you the colors you want.
Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
Thanks Jorge!
I actually find the way to use the old EAGLE colors (which was not the default in my case) just today but was wondering if there was a setting to revert back to the Fusion360 colors (orange components just to be clear)
Hi @ruben.crispino,
I hope you're doing well. If you go into Fusion 360 > Preferences > Electronics > Color there is a button that says reset to default colors. Click it and that should get you the colors back. You can always change the colors to whatever palette you prefer.
Best Regards,
Jorge Garcia
