Fusion Electronics
Working an electronics project and need help with the schematic, the PCB, or making your components? Join the discussion as our community of electronic design specialists and industry experts provide you their insight and best practices.
Schematic and Board empty
1 REPLY 1
john.baillieMKKGY
141 Views, 1 Reply
I reopened my Electronics Design Project today and the Schematic and Board files are completely empty. The tab of the Electronics Design which show previews of the schematic, board and 3D file are showing the files correctly (ie they are populated with components and are not empty).
I have opened previous versions of the schematic files and all of them from the last day are corrupt (showing only one, empty sheet). I have to go to the previous days' versions to find a version which correctly shows the file. Obviously I would rather not lose a days' work.
This has happened before however since I only made a few changes I was OK with going back to the previous day's version, but this time I spend a solid 12 hours on the design 😓
All of this started happening after a Managed library was acting weirdly.. when I tried to push changes to library.io it got stuck on 'checking 'library name' for updates'. I restarted and thought that solved the problem. Not sure if it's related but thought it worth mentioning.
I tried to download the files to open in Eagle standalone but get the following error with the .brd file
Error:
line 2293, column 97: attribute 'package3d_urn' references undefined object 'urn:adsk.wipprod:fs.file:vf.qqIbtWyAQn6Oy1hdOwmlJg?version=2' in tag <package3dinstance>
Hope you can help as I'm completely stuck now 😞
Tags (1)
1 REPLY 1
Hi @john.baillieMKKGY ,
I'm sending you a DM. Let me know if there's anything else I can do for you.
Best Regards,
Jorge Garcia
​Product Support Specialist for Fusion 360 and EAGLE
